Clint thanks for the
reply, I had hoped you didn't take any offence to my post, I certainly didn't
mean any. After I posted it, I re-proofed it again, and it sounded a little off to
me, so if you saw what I saw, I apologize.
I have been studying about Damascus for a while and your pattern there looks
similar one I want to try once I get my welds down, it's one I read about in one of Jim Hrisoulas' books, I think it was "The Pattern Welded Blade", but don't
quote me, I have "The Complete Blade Smith" as well, I sometimes get them
mixed up together. Anyway, the pattern I'm referring to is (I think) called the
"Pool and Eye" pattern, it kinda...sorta, looks like wood to some, or so I read.
The technique used with that one has the maker drilling various size holes into a straight laminate billet, of different depths. Depending on the desired thickness
of the end billet. I said all of that to ask this, in your billet, you have what looks,
to me, like you used the drilling method on part of it and also you have what
looks like a Ladder Pattern at the edge, which I might add is freakin awesome!!! If this isn't the way you got this pattern, would you mind explaining how you
did?
I understand your philosophy on treating a Damascus billet just like you treat
any steel, and that would be my problem, instead of seeing the blade in my mind like I normally do, I'd be thinking,
"DON'T MESS UP, DON'T MESS UP!!!!" I still consider myself a newb and with
an unexpected 4 month absence from the shop, I'd be sure to destroy it!
I know A LOT about design changes, the problem with my design changes is
there isn't usually enough steel left to make a knife! When I screw one up, I
screw it ALL the way UP!!!
Thanks Bud, I appreciate you sharing your time, Rex
