Denny Eller
This is a super WIP, Erin and thanks for doing it.
On a different note, I was reading the paper on the AF Base where I work today and found out you were being a little modest about your father in law. Maybe you didn't even know the whole story but...
Check out the link guys and scroll to the top of page 5A:
http://www.robins.af.mil/shared/media/document/AFD-100205-018.pdf
Some of get to see these guys all the time but we still need to stop every once in a while and tell them thank you.
Thanks again Erin,
Carey
All I can do is sit here with my mouth wide open thinking...." knife #8"???????? I think we need to keep our eye on your bro.
Chris
Knife #8 may be a bit misleading as Knife #7 consisted of five knives of the same design (7a thru 7e). So technically, Knife #8(a) is actually my twelfth knife completed. Confusing, but that's just the way I roll.
Erin
Would it be possible to peen or press mosaic pins?
Or would it distort the pin pattern? Just thinking if it was cut close to the guard, you might be able to swell it a bit.
Very well done. The only thing I would suggest that I noticed right away were the mosaic pins. Someone once pointed this out to another maker and it's something I look at right away whenever I see them. Rotate them so they are identical. It's considerably more noticeable when they the design has more of a "+" shape design to them as opposed to a triangular one like you're using.
For example you can see knives with 2 mosaic pins done in the handle and one looks like this + and the other like this x because they weren't rotated in the same direction.
