Welcome to KnifeDogs
A Family Friendly Knife Oriented Community Founded For Knifemakers, Collectors, & Enthusiasts.
  •  » Forums for individual knife dealers.
  •  » Forums for businesses supporting the knife industry.
  •  » Knife makers individual forums for visiting, support and sales.
  •  » Forums for knives.
...then you have come to the right place!
we will try to help you with your problem.
YES! I want to register an account for free right now!
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Finishing Plunge Cuts on the Grinder (How I do it)
  1. #11
    Join Date
    Mar 2014
    Location
    Brea, CA
    Posts
    166
    Ed, as always, thanks for taking the time to pour your knowledge back into the craft. The video was short, sweet and too the point. The video and audio quality were both great. There are tons of knife making videos on Youtube that have good info, but are hard to get through because the quality is bad.
    Thanks, and i can't wait to see more... I will watch them ALL!
    - J
  2. #12
    Join Date
    Nov 2011
    Location
    Santa Monica Ca.
    Posts
    6,431
    Thanks Ed,
    Behind every great dude is a great Dudette!
    Thank Cindy for us.
    Laurence
    www.rhinoknives.com
    www.westsidesharpening.com
    Maker and seller of Rhino Finger Skins Thermal protection for grinding harden steel.
    www.rhinofingerskins.com
  3. #13
    Join Date
    Dec 2010
    Location
    California
    Posts
    1,117
    Cindy gave us all a great gift. Thank her for us.
  4. #14
    Join Date
    Jun 2013
    Location
    North East AR
    Posts
    184
    Great video. Thanks for posting it.
    If you are taking requests, in keeping with the same theme how about your method for grinding and establishing the plunge cuts we just cleaned up?
  5. #15
    Join Date
    Jan 2012
    Location
    S. Baldwin Co., Alabama
    Posts
    1,824
    Ed, the whole bunch is thankful for your wife - she did GOOD!!! The image quality of the video is only exceeded by the knowledged shared, so THANK YOU also. Glad to hear what you said about hand sanding to blend the grind line to flats at top of blade. I've had a VERY hard time getting a nice straight grind line, and felt I was cheating when I blended. BUT - now that I know the "Great Ed" sometimes blends, I feel better {g}
    Ken H>
  6. #16
    Join Date
    Feb 2014
    Location
    central valley of Calif
    Posts
    706
    Thank you Ed!
  7. #17
    Join Date
    Jan 2012
    Location
    Posts
    1,824
    Hey Folks, I just tried Ed's info in the video - using a J-flex belt, let about 1/4" roll over side of platen, and it sure does clean up that plunge nicely. I use a file guide with a round file to file a plunge in, then finish up on grinder. Always was some file marks that took a LOTS of sanding to get out. With this at 400 grit J-flex - nice 'n smooth.
    Ken H>
  8. #18
    Join Date
    Jul 2014
    Location
    Kansas City
    Posts
    315
    Ed,
    I do have a question for you regarding the j flex belts vs stiffer belts. How do you get the lower grit scratches out?
    The problem I'm having in the plunge cut are the deep 40 or 60 grit scratches from the Orange blaze belts that I can't get out. I love using my Trizac gator ceramic belts from A300, A150, A100. A65. A45. A5.(I don't remember the grit equivalent for the Trizac Cm belts, I'll post it up in a bit) My last 300 belt is too worn to use but it never really took out the deep scratches well. I used a bunch of cheap belts in the 120-220 but they never flexed over the edge.
    I know there are a ton of threads on here and elsewhere regarding belts. However, Ed what belts do you use or would recommend I get between the 40 grit blaze and the 150 gators ceramics? Am I starting too low in the grit with a 40?
    Regarding pre or post ht grinding. I grind the small folder blades post ht, thicker blades I've done pre so far.
    Thank you for any help you can give me on this.
    John
  9. #19
    Join Date
    Jul 2014
    Location
    Kansas City
    Posts
    315
    Just found the grit chart conversion from a post from the Big Dog.
    MicronsP GritCAMI (typical US)
    A30p600360
    A45p400300
    A65p260220
    A100p180180
    A160p120100
    A300p8060
    John
  10. #20
    Join Date
    Jun 2011
    Location
    Nova Scotia, Canada
    Posts
    1,800
    Great video, Ed sure makes it look easy.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
