lerman
Hello,
it's been a while since i last made a full WIP, i have just started making some knives for the helsinki knife show in january and this is the first project.
hope you'll enjoy it.
cutting the O1 on the band saw
rough contouring
final contouring
marking the edge
marking the grind height
this is a good opportunity to show off my new file/grinder guide, it's made out of stainless with a full carbide faces, works great.
rough grinding, 40 grit ceramic belt
and after, 300, 160, 100, 65, 45 and 30 3M trizact belts
rough grinding of the false edge
and fine tuning with a file
drilling the holes
and some weight reducing holes
flatning the snake wood scales on the disc sander
drilling the wood
rough contouring of the handle, 36 grit AO belt
and a 220 J-flex belt
some hand sanding
220 grit
320 grit
rough shaping of the handle with the stop pin machining method
some more shaping with 320 flex shaft
hand sanding- 600 grit
up too 8000 grit
and after some oil
rough contouring
final contouring
marking the edge
drilling the holes
drilling the wood
some hand sanding
220 grit
320 grit
up too 8000 grit
and after some oil
