Eddie Mullins
I just thought I'd share some pics of my current project. A small game skinner that I designed. I hunt Mountain curs on coon an squirrel and thought I'd make a knife I could use hunting. This will be the first knife I hopefully finish. I don't have a sander so this will be done with basic tools, and forged from spring steel. My goal here is to just finally complete a knife, and have a functional hunter, and hopefully learn.
The sketch and template of the knife, blade is 3" and handle just over 3".
The template and spring steel I started with. The spring steel is pretty thick so I took a guess at the size to start out with before forging.
I guessed a little on the large size. Here is the as forged knife (I am using a coal forge I built myself). As you can see its larger than my template so I had to do a little trimming.
Here is the knife after doing the initial rough shaping with angle grinder and files. Not quite an exact match, but pretty close. I left the blade a little long. I figured I can always take more off later if desired.
I'll post more as I go. Comments or critiques welcomed.
