"Magnum" Platen
"The Montana Bladesmith"
For a while now been considering a larger platen that I could interchange between my grinders. the "Caffrey" platen works great, but I've found the need for a longer platen when working on longer blades. Last week I decided it was time to just build it. After a couple of days of trial and error, I came up with the solution I needed. It retains the 1 1/2" (top) and 3" (bottom) contact wheels that I've come to find indespensible, but where my standard "Caffrey" platen has a max platen face of about 7 1/2" long....this one has a max platen length of 10 1/2".
The platen itself is actually a three piece design...... 1) The "platen holder" which started out as a piece of 3/8" X 2" angle iron, and attaches the platen to the attachment body,
2) a piece of 5/16" X 2" A36 hot roll, with a "shelf" at the bottom, and the Pyroceram platen face, that is acraglassed onto the A36, and attaches to #2 with two 1/4" X 3/4" button head screws.
Here's a pic of the glass faced platens that are interchangeable.....the one on the platen is 8 1/2" and that one I'm holding next to it is 10 1/2".
For my grinder setup, I think I've reached the maximum platen length.....unless I start raising the grinder with a thicker "platform"....but then the height of the platen wouldn't be "right" for me.
In case anyone notices.....there is a reason for the "gap" between the bottom of the platen face and the lower contact wheel......that is where I create my convex edges during finish grinding, as well as many other task where a "slack" belt is need, and I don't have to change attachments. It's not as versatile as the original "Caffrey" platen, but I'm learning that in certain situations, I'm willing to take the time the change attachments. :)
I did have to make one major modification to the KMG.....I had to trim the base plate, so the belt didn't "rub"...........
Just thought I'd share, in case there is anyone out there who might find the need for a longer platen as I did.
If the pivot on the platen was lower than the mid point, would that eliminate the need to trim the base? Would the top order wheel then be higher than the tracking wheel? Thanks
Ed,
Very nice looking tool you have made there! Glad to see you are feeling well enough to work and design in your shop!
You really could make a longer Platen , By putting the KMG on a riser plate and making a box for you to stand on to make you taller so you still reach the Platen at the right angle. :biggrin:
Good idea for those long Bowie and chef knives.
Laurence
www.rhinoknives.com
