Shane Wink
In the name of enthusiasm to be out making knives in the shop I would like to share a little bit of joy. I am not a master or expert so take any advice with that in mind. The fact is that the wharncliffe is my favorite utility design and one I use more than any other for most cutting task around the house and when on duty. Now dont get me wrong there is not a single design that can do everything great but finding a design to fit your needs and one you have knowledge of how to use that design so that you can preform most of your task well is a good thing indeed!
For me the only short coming I find with the blade has been when trying to skin small game. The straight edge just has not been that easy to use and I find most of the time I am poking hole all in the hide. That has been my experience thus far with small game and may not be yours. I also find that I miss that a bit of belly to rock the blade on when cutting veggies and slicing venison. Using just the tip of the Wharncliffe scares up the cutting board real quick so it needs to be a little more user friendly in that respect.
So whats the point of making knives if you dont try to build a blade to fit your needs? Not reinventing the wheel nor will I even most likely be making something original. After all with so many makers that have lived I doubt there is much that has not been made at some point, however with that said I wanted an EDC that would also serve me in the woods as well. What I came up with is best described as a modified wharncliffe Loveless EDC.
Specs:
7/64 01
8" OL 3.5" blade 1 3/16ths wide
Ghost Jade G10 scales
I drew out the shape several times till I had what I was looking for. Once scribed out I cut it out with the bandsaw
Flattened the blade, ground the bevels and edge down to .015, slightly rounded the spine above the blade and hand sanded the entire blade to 220.
Drilled the handle and throng holes, counter sunk them, filed the tiny notch at the blade and ricasso and another notch on request by a buddy on top of the spine for lifting his tea kettle off the fire. He saw the notch on a knife in the BackWoodsman Magazine and wanted to try it out. After I placed on on his other bush blade he has asked for them on all his bush blades.
I have run out of time and will do the heat treat Monday then the scales. Thanks for reading and I hope you enjoy the build.
Specs:
7/64 01
