Hello all, I'm in the process of building a 2"X72" grinder based on the KMG grinder, and have made good use of the grinder plans by Mike Clerc: http://www.metalwebnews.com/manuals/knife-grinder.pdf
I have the platen setup with a 2" aluminum wheel at top and bottom of platen support
I have two questions here.
1. When adjusting the Platen support with the Platen mounted - Just how much clearance should there be between the platen and back of belt? I'm thinking the belt should just "kiss" the face of platen putting only a slight pressure (1/32" interference?). OR should it have a bit more pressure just sitting there? Or just clearing platen when not running?
2. When adjusting the tracking wheel to get belt to run in center of drive pulley and other wheels, the tracking wheel is angled down rather than looking level. Is that an issue? If so, what could be some of the causes? By adjusting the tracking wheel, I can move the belt from side to side on the wheels.
Thanks for any help or suggestions.... (I need all the guidance I can get<
Ken H>
Ken H>
