Josh Dabney
Moderator
Kelly,
I already burned through the tax bucks plus quite a bit of additional $$$$ I'll be FLAT broke by the end of the month once again but the new tools in the shop will last ALOT longer than the tears :biggrin:
I do have a full set of the u264 belts from 100x to 5x that are still basically new. I'm curious where you got the new u936 version though as I looked around and didn't see them listed on anyone's website ?
My problem with grinding to a high grit finish is getting an even belt finish where the convexed edge meets the flat ground bevel. I'm hoping to get some better results with the Rotary Platen but I'm honestly not getting my hopes too high :9: Beginning handsanding at 320x is about the best I've been able to achieve with the geomerty I want on my blade.
I have had good success at grinding blades ultra thin with a full flatgrind though and can get a great looking belt finish off a 600x cork belt.
Thanks for the tip on the u936's buddy ! I'm always game to try a new belt
-Josh
-Josh
