Frank Hunter
Here's some first hand information on working with Dymondwood and similar laminates. This might apply to some makers but not all as it's not a high-value material but is very consistent and durable. Not to mention inexpensive for the color range available. A few things I've found -
Your handle pin holes will end up smaller than the drilled size. It's more noticeable in this material than other woods I've found for this so far, I don't know why the holes shrink so badly in this stuff but they do. A 1/4" bit leaves a hole that in no way will fit a 1/4" pin like the steel tang would. I use either a round rasp to slightly open it up or you can use a 9/32 bit on the scales. It also will occasionally shrink after installation and leave a slight amount of the tang proud of the finished surface, I've noticed this in the "Walnut" but not the "Silver/Black". Also, even though requiring no oil or polish aside from green or pink compound on a buffing wheel, it will burn yellow and brown if you get it too hot.
The dust is nasty and percolates a good 30 feet from the grinding area and will give you Technicolor boogers matching the current color you're working if you don't use a respirator, it seems to get around a dust mask to a greater extent than the natural materials. I haven't had my grinding bin catch fire but it will smoke and probably should be treated as much of a fire hazard as regular wood dust.
Any other points or specific thoughts about this stuff?
