C Craft
Have you ever notice when you grind something with a drill/drill press turning the object tends to be off center! FOR EXAMPLE: Lets say you have a center punch and the point gets a little mushroomed.
So you chuck it up in your drill or drill press and you grind/file the new point.:3:
Then when you can't seem to punch consistent starter dimples. :les:
You turn the newly ground center punch up and look at the point and dad-blameit the point is off center!
I always thought maybe it was wobble in the drills chuck, but I have tried this with a new drill and same effect. I have locked the grinding/filing apparatus down and same effect, off center!
Some days when the Sun and the Moon align and Jupiter is....................... well, some days I can hit center better by eyeball!
I have one center punch that was very cheap and I litterly ground it down till it's almost dangerous to use now, trying to come up with a solution to make the newly ground point center better!!
So my question is WHY , and what can be done to make it center better???? I don't have a lathe, so there has to be a solution to whip this problem short of buying one!!!
Please don't try to tell me that I am the only one who has ever experienced this, cause I ain't gonna buy the pile of dog stuff!!:s12205:
