I think you may not like resawing that material that thin. Mammoth ivory has a strong grain that does not run horizontally. The grain is slanted. A tusk is basically a series of stacked cones. Cutting along the scales laterally may (likely) crack the scale along the grain in a bad way and you could lose a scale. Mammoth is at least 10,000 years old. What appears solid, frequently cracks along the grain when cutting it. I use a 14tpi blade and some times use 18tpi if the ivory is fairly fragile. Knock it gently on a hard bench and feel if the piece is dead solid or less than that. If you feel any looseness in the piece, look for cracks and apply thin super glue to let it wick in and set up. God luck. Cutting mammoth is always a gamble. I have cut enough of it to know I don't like cutting it.
