Hello all. Long time lurker.
Here goes.
I picked up an older Cress kiln. Specs are: model C-200-E. 230 vac. 8.5 amps. Manual control knob from Lo to Hi with graduations 0-100. Old school pyrometers. Warning in front states do not exceed 1700F.
I want to use it now as my heat treat oven for simple carbon steel, 1084 mostly and perhaps some 5160. It will eventually become a tempering oven to keep me out of her kitchen. Yes, I said her kitchen. She owns it.
I want to build a PID controller that I can simply plug the kiln into and then plug it into the outlet in my garage. 240vac, 50, new construction so no worries about capacity.
My question is would someone post a schematic showing the wiring for such a project. My concerns are as follows:
1. How do I deal with the incoming 240 and allow it to power the PID controller and then have a switch on the output side for a receptacle?
This is really to keep from rewriting the kiln and simply using it as it is with a new thermocouple.
Does this make sense?
I know nothing about this save for watching many YouTube videos and not seeing anything that explains using 240 vac.
Thanks in advance.
Sent from my iPad using Tapatalk
Here goes.
Thanks in advance.
