Thanks Smallshop!! Did a little digging around and found a manual online. Calls for Vactra Oil Heavy Medium. Found some Mobil Vactra No. 2 Way oil on Amazon. Do you think that will work?Only run way oil...prolly 20 weight if ways are good...otherwise 30-50 weight. If you can get a manual follow the mfg recommended lube.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
