D.Douglas
I had to contour some bolsters on a slip joint i am working on and wondered if other people might want to check out my method. Having a strong jewelry making background i use a file and a some sanding sticks. The sticks use a 11" strip that are quickly changed out. Great for a little contour. You can rough grind somewhat close say at 45 degrees on the edges then take over with the file and on to a 220 stick and then 320 likkidy split. Very accurate also. I also use a optivisor for a little magnification for my old eyes.
