OK, for me it's a first. I'd always figured it was too expensive, to hard to get...... all the usual excuses. Come to find out the grocery store only 5 miles from here carry dry ice! Right there in the frozen food section in a "deep freeze" type thing. Just serve yourself - $1.50/lb. I picked up 3 lb to play with. I happened to have 3 blades ready for heat treating, so I turned oven on.
I also found why you don't use Isopropyl alcohol - it freezes with dry ice! I took container outside, pour a bit of acetone in - nice liquid ice mix.
I had one steak nice type blade that was a bit too long for liquid, so only the blade was fully covered leaving the tang outside liquid. Rc testing shows the tang is 2 points less than blade, just as Sandvik said it would be.
I might have to do this more often/
Ken H>
Ken H>
