willows
Hello guys, I present my latest creation, or rather a new version of Condor, with pins and pin to open the blade of stainless steel, new pin made by me on the lathe turnings with landscaping and a general revisited .
Steel blade Aisi 02 (high carbon steel), polished. Grips in Corbezzolo root. Folders tempered steel of 1.5 mm. Filework on the back of the blade and folders. Teflon washers.
long when open 20.5 cm - 8.08"
blade length 9.5 cm - 3.74"
closed length 12 cm - 4.73"
blade thickness 3 mm - 0.12"
weight 135 g - 0,3 lb
I hope you like it
Greetings to all
I hope you like it
Greetings to all
