The $120 for enough Koa-Wool or Inswool to line your forge is not a little rich, it's outrageous. It's been a while since I've priced thing on the site but I think that you could get an entire roll of 1" 8# Inswool at High Temperature Tools and Refractory for less than that. Enough to do several forges. I don't find the rigidizer to be useful and it does reduce the insulating qualities of the ceramic matting. Do get something to coat the matting on the inside of the forge with to prevent the inhalation of fibers once the forge has been heated. Some use a mortar like Satinite but I prefer a castable refractory. The rigidizer will not do that job. In either case moisten the matting slightly with a spray bottle and apply the product. For the castable refractory what I did was apply the product on the bottom and as high on the sides as it will hold. I then gave it a little time to set up and then rotated the forge body onto one side and coated that section, let that set up a bit, then repeated the process on the other side. Give the refractory a few days to dry then slowly bring the temperature up in increasing heats to cure the refractory shell.
Doug
