Kampman Knives
Hey there,
I have been trying to weld forge cable damast for about 10 times and i don't know what i am doing wrong but at the end i don't see any pattern, getting pretty frustrated here so i hope someone can help me out?
I know how to forge weld and to work in the right temperature, i have been making my own damast and i do everything by hand - i don't have a power hammer.
Here's what i do:
- Clean the cable from grease and dirt.
- Cut them in pieces about 15 cm.
- Weld the ends together.
- Heat it up till its orange and give it a extra twist so the cable is more tight.
- I bring it up to the right temperature to yellow and flux it before and after, i keep it clean from scale with a wire brush.
- I keep forging till i have a solid bar and all sides a good forge welded.
- Than i work the bar out into a flat piece from where i can make a shape for a type of knife.
Than i check the cable damascus bar by grinding and sanding it shiny to see the pattern, and than i use ferric acid or others to etch and the pattern would normally come out like damascus.
Until now i barely see the pattern and it looks like one piece of solid steel, when i etched it nothing happens except that it darkens the steel??
I don't work to hot and if i would work to cold it doesn't weld together,....so what is going on and what am i doing wrong or is possible that some types of steel cable are not good for cable damascus?
Here's what i do:
