cardoso5fr
Another slip joint with spyderhole licensed by spyderco. 90MCV8 blade, 3 mm thick, full hardening. 200°c tempering. 100MnCrW5 spring, oil hardened, and 340°c tempered. 6.2 cm sharp, 16cm long, thick 1.5 cm. Silvernickel liner and ebony handle. One screw should have been put in the middle of the handle but i tappered the liner before to shape the handle and was a full dumb....
The spring is strong but it's possible to use the spyderhole as one hand opening system without problem. I countersinked the spyderhole and i should not .
I have some more work before to make one fully perfect (with the screw in the right spot and with the spring tension and spring movement that i intend to have. That i'm really happy with that one
