QUench oil
HELLGAP
Dealer - Purveyor
I have only 4 Damascus blades whats a cheap quench oil I believe the steel is 1085 or 1080 and 15n20 nickle . Can I use canola oil or olive oil . I am just using a map gas torch and a magnet . If its at all posibble ide like to use virgin olive oil I havent had any in a while .
Any of the organic cooking oils will work. Some folks find it better to warm the oil into the 100 degree F range before quenching. Peanut oil will also work well. Good luck.
