scott.livesey
Dealer - Purveyor
True cross-rolling is where the rolled piece is rotated 90 degrees after each pass thru the rollers. this is from Langley Alloys:
as said, the idea is reduce any effects of 'grain'. I have only seen the term when looking at tool steels, although you can probably find any metal cross rolled. i think what we see and call 'Grain' is the finish left after the steel was ground to thickness, especially when you buy "Precision Ground Flat Stock". I guess the steel is rotated during grinding to help achieve advertised thickness of */- 0.001.
With the basic hot rolling process as detailed above, it is found that plates have a very strong directional grain flow which can lead to down stream difficulties in cutting and fabrication. This is due to the resulting differential characteristics of the properties and structure with in the plate. Cross Rolling, where the plate is repeatedly turned by 90 deg. through its production rolling program giving plates a greater uniform microstructure and homogeneous properties both in the longitudinal to transverse directions across the plate. |
