WY_Not
Found the knife below while out in Wyoming. The blade has the distinctive Old Hickory line pattern stamped into the blade but it has NO markings that I can find anywhere. Don't they normally have the name etched in the blade and burned/stamped into the handle? Or is this one just so well used that both markings have been wiped out by time and use? On the right side of the blade you can still see them pretty well but on the left side they are very very faint near the handle then as you go out further, they become non-existent. Looks like one of the rivets came out and someone at some point put a nail in there, cut it off and peened it over as a makeshift rivet. Edge is in good shape, just needs some TLC to make it truly sharp. I'm thinking it is the Old Hickory 6 Inch Household Boning Knife but the spine is completely flat, there is not curve to it. Looks like it has seen a lot of use.
Can try to get some better pictures in some better light tomorrow.
Regardless of what it is, I'll be using it to practice putting scales on a knife and shaping the scales. No idea what it is going to end up with as far as scales go. Wife hasn't even seen it yet and is already trying to claim it as her new kitchen knife... after I put new scales on it of course. :15: :34:
