Fred Rowe
Help me out here guys!
The ERU is a work in progress and I'm always looking for ways to improve on the original. I posted here in wanting feedback from you folks, who understand sharp.
The inserts in the ERU are set using a precision square; they are set along both axis relative to the degree indicator. This is not accurate enough; the human eye won't produce the accuracy needed. To reach its potential the carbide inserts must be lapped after they are mounted in the individual aluminum disc.
The fixture pictured below allows the carbide surfaces to be lapped, on a diamond plate, square relative to the sharpeners axis. The result is more surface area abrading the edge when drawing a blade is pulled through the carbide "V". It's pushed the degree of sharp up a considerable amount from the mechanical setting.
This sharpener, with its carbide inserts lapped on a diamond plate will produce shaving sharp edges without stropping. I was amazed at the difference from the original.
Thanks for your input, it has been invaluable, Fred
If you purchased an ERU from the first run of 50, [orange] contact me or drop your sharpener in the mail and I will lap the inserts and return it to you.
