on/off switch for my NWG?
Geoffrey
Active Member
I have my NWG frame all built, ( well did, I tore most of it apart again and I am making a few modifications ) I have my motor mounted and I am getting ready to do my electrical work.
Years ago I did work on power tools, electric motors, etc but time/age seems to have taken all of that I once knew.
I am planning on using a 10 gauge wire with a plug on one end, a electrical box with my switch then a wire out to the motor.
My motor is 115V, 16amp, and 1.5hp.
What do I need for a switch?
My motor has a wiring diagram for CW and CCW so I am sure I can follow that. Just completely spaced on what I will need for a switch.
Thanks all! :biggrin:
Geoffrey
I have a wiring kit that includes an 8' molded power cord, cable gland, wire nuts, switch with dust proof rubber boot and wiring instructions. The 115v is $45.00 and 230v is $60.00.
I knock out one of the smaller knock outs provided on the wiring box for the wire entry and cable gland and another to mount the switch.
If you don't go with Wayne's kit, you can really use just about any SPST switch, as long as it's rated for 110VAC/15A or so.
I use a standard light switch for mine.
Thank you both.
I ended up finding a motor rated switch at my local motor supply. It'll work with my current 110v setup and will also work when I get a 220 outlet in.
I wired it up and it seems to work pretty fantastically.
Thanks again.
