Wiring 3 position switch to run motor forward/reverse without rewiring
E on the switch
T2 T4 and the white neutral from the 110 power source. did you possibly mean P2 and T4 and the Neutral
The jumpers look like they will activate all the contacts no matter up or down. Ill test it later thanks.
SUCCESS,That worked perfect switch down CCW, up CW I keep it off the middle and just use a toggle for power
People have been asking this question for a while on different forums about a cheap 8 dollar DPDT to make a motor like this reverse. Thank you, and thank you again I hope this helps some others.
Thank you Count !! I wish I had this info years ago before I spent all that money on a drum switch. Valuable money saving info that I will use to build my next disc sander, awesome !!
Clint
If you wire this switch like this, you can't use the center position with power ON. Make sure too wire a power switch or just plug and unplug. NO POWER ON while changing the Forward and reverse switch if that makes sense.
