DonL
I started experimenting with a Hamon using 1075/1080 on 1/8 steel. I went to Radio Shack and bought some PCB etchant a diluted it 1 part acid to 3 parts distilled water.
While tempering, I used Satanite for the Hamon.
I put the knife in the acid the first time for 5 minutes and it had a nice finish. I washed it off and wiped it down. It didn't look quite right so I took a scotchbrite pad to it and pretty much removed all the dark finish on the hardened steel and a lot of the grey finish on the softer steel. The hamon was still present though.
So I redunked it for about 2 minutes and this is what I got. I personally like the grey finish on the softer spine, but I'm not all that thrilled about the darker finish on the hardened steel.
My questions are:
Is this finish durable or will it wear off? Are Hamons a good idea for a knife that's used a lot?
Is there something else I should be doing to the finish other than washing it off with water and drying it off?
Any other suggestions will be greatly appreciated! I have several more smaller knives that will be ready for the acid soon unless I change my mind.
My questions are:
