Help
Jerry Bond
Ok Dogs, I have a 0-1 skinner with gut hook, Heat treated yesterday. Today I was going to temper. Just turned the kiln on prog 6 and stuck in. set a separate timer @ 2 hr 15 min [15 min to get to temp] When the timer went off
at the end of first draw, I noticed the temp was set @ 385
[I forgot that I had changed it]
Now should I reset temp to 350 for the next 2 hr, or re-do the h'treat?
Thanks for the help guys, my mind is sorta blank rite now. Jerry
you shouldn't be that far off, follow up with the 2nd at 350
