Addicted to dovetails
jkf96a
I started dovetailing my bolsters about 6 or 8 knives ago. They're turning out good, don't think I'll go back to straight joints. I've been doing my dovetails on a disk grinder with a tilt table. How do you do yours?
I do mine on a square wheel grinder which has an adjustable flat platten. Do dovetails one way turn handle material over upside down and dovetails match.
I made myself a wedge of about 20 degrees and place on my FIXED table with a flat platen. I've used it for about twenty years, first on fixed blades and then when needed on folders. Frank
There was a guy that made dove-tailing jigs awhile ago and I picked one up. Awesome piece for getting it just right! I'll take a photo today when I get a chance.
Here's a recent one. I had to pick these from thumbnails, hope the dovetails show in this pic.
I think dovetails are fantastic.
I use them on most of my folders. I set my tool rest in front of my flat platen to give me a 60 degree angle. I then grind both the front and rear bolsters. After they are attached to the liner, I then grind my handle material to fit. Then I slide it into place from the side.
60 degree works well for me since I can clean up any solder with a triangular file.
Johnny Roberts
Nice fit-up there Johnny. The ones I did in the pic above are also 60 degree. I've done some 45's as well, and they look good too. Any consensus as to which is preferred by collectors?
